[Solution] Airtel Message Center Number Unable to Send SMS from Airtel
Airtel is one the most popular network in India. Most of the people are using SMS and sometimes they will facing issue with not sending SMS. If you are unable to send SMS for prepaid, postpaid or 4G. In this article, we will be revel solution for sending SMS. Follow these steps to resolve the airtel sending problem.
SMS not sending problem is really frustrating. Some users thinks sending not SMS problem is a network issue. But, It is not a problem with a network issue. So, they try again to send SMS but it will again fail to send SMS. This error is not a networking issue. It is due to the (SMSC) Short Message Service Center Problem. Generally, all message settings are default when you install SIM in your phone. But, it might be changing in the message setting which causes not sending SMS. Follow the below instructions to solve the issue in your phone.
How to Solve the Airtel Message Center Number for not sending SMS?
  1. First, go to your mobile settings. open it.
  2. scroll down and then go to the system apps, open it.
  3. There are many system apps options available, open the messaging app.
  4. Choose the Additional Settings and open it.
  5. Open the short message service center.
  6. Put Airtel locality mobile number in SMSC number.
Here, you get the airtel locality mobile number which you can put them into SMSC. Different States has different SMSC Number.
Below List has different States with different Airtel Message center Number. check out now.
Andhra Pradesh -- +91 9849087001
Arunachal Pradesh -- Coming Soon
Assam -- +91 98180230015
Bihar-- +91 9831029416
Chattisgarh -- +91 9845086020
Delhi -- +91 98100-51914
Goa -- Coming Soon
Gujarat -- +91 9831029416
Haryana -- Coming Soon
Himachal Pradesh -- Coming Soon
Jammu & Kashmir -- +91 845086007
Jharkhand -- +91 9845086020
Karnataka -- +91 9845086007
Kerala -- +91 9810051905
Madhya Pradesh -- +91 9845086020
Maharashtra -- +91 9898051916
Mumbai -- +91 9898051916
Kolkata -- +91 9845086007
Mizoram -- Coming Soon
Nagaland -- Coming Soon
Odisha -- +91 98180230015
Punjab -- +91 9815051914
Rajasthan -- +91 9898051914
Telangana -- +91 9849087001
Tamil Nadu -- +91 9898051914
West Bengal -- +91 9932029007
You can check SMSC number for your states. From the above list, check your states SMSC numbers and put in your locality state. If any problem related to this article, you can ask in the forum, we will be happy to help you. Register Now.
