OFFER Orpat OEH-1220 Room Heater Best Price on Amazon
orpat oeh-1220 room heater specifications
  • Ideal for a small / medium room only, i.e., up to 250 sq. ft. when operated at 2000 watt heat setting. Makes some noise due to fan
  • Refer the wattage chart image for locating heater wattage requirement for your room size
  • Plug type: 15A, do not plug in the standard 5 or 6A socket, you may require a 3 pin plug or extension cord to act as a 5-15A convertor but can not be used for long time with extension cord
  • Non sagging, stitching type and long life heating element
  • Safety cut-off
  • Thermal cut-off for added safety
  • Two heat settings-1000 watts and 2000 watts
https://www.amazon.in/Orpat-OEH-122...m=A1VBAL9TL5WCBF&pf_rd_r=FNRTH1AE2A6PAV43E8QB
