OFFER Boult Audio Tru5ive Bluetooth 5.0 Wireless Headphones in Deal Price Rs 2849
- 100 percent waterproof 5.0 Truly Wireless: Listen to your music truly wire-free with Bluetooth 5.0 Tru5ive Stereo TWS form factor which is completely waterproof
- Built-in Mic: Built-in HD condenser MIC for Calls and Siri/ Google voice command; Though calling function works only for 1 earbud (Mono audio)
- Auto-pairing: Automatically pair with your device as soon as you take them out of the case. No need to manually pair to your device each time
- Interchangeable ear loops: Tru5ive comes with 3 color ear loops; Green, Grey, and Pink; Simply change the ear loop on earbuds according to your color preference
- Deep Base and 3D acoustics: The In-built Neodymium technology provides immersive audio, heavy bass, and passive bilateral noise isolation
- Charging case pod: Be unstoppable with the handcrafted alloy charging case that will charge the Tru5ive 3X lasting you almost an entire day
- Compatibility: Works with all OS, all Bluetooth enabled Smartphones, Laptops, PCs, Tablets, Smart TVs, from all the brands
