Logitech M235 Wireless Mouse
Logitech M235 Wireless Mouse in offer. Rs 499
  • System Requirements :- Windows Vista, Windows 7, Windows 8, Windows 10, Mac OS X 10.5 or later, Chrome OS, Linux kernel 2.6+, USB port
  • Wireless operating distance: Approx 10m, 1 AA battery, 12-month battery life
  • Advanced 2.4 GHz wireless connectivity (Unifying supported)
  • Sensor technology: Advanced Optical Tracking, Sensor Resolution: 1000
  • Receiver Weight: 1.8 g, Mouse Weight (including battery): 84 g
  • Mouse Dimensions : 55 mm (2.17 in) x 95 mm (3.74 in) x 38.6 mm (1.52 in), 3-year Limited hardware warranty
  • The adapter of mouse is located at the bottom of the panel,USB port can be found by opening the battery cover at the back of the mouse
https://www.amazon.in/Logitech-M235...m=A1VBAL9TL5WCBF&pf_rd_r=YBV6BGXNV6H9WJ7RA509
