Huawei P30 Cost of Rs. 71,990
Prime Member early access the device on 15 April. Huawei P30 Cost of Rs. 71,990
Also, get Huawei Watch worth Rs. 15990 at Rs. 2000
The Best Feature about it's camera..
40+20+8+32 MP
It has 50X zoom capacity to closer your objective.
It has 8 GB RAM, 128 GB ROM, 256 Expandable.
Kirin HiAi System.
4200mah battery.
More new Features are available in the Huawei P30..
Buy the Huawei P30 Pro Online at Amazon India
Elegantly designed for performance, the Huawei P30 Pro assures a great smartphone experience. With a super camera system, this latest smartphone by Huawei allows you the capture stunning images and videos in high clarity. A true technological masterpiece, purchase the Huawei P30 Pro at Amazon.in and avail exciting deals
Experience an Unmatched Camera System
Giving you an incredible camera system, the Huawei P30 Pro is equipped with a 40MP camera, 20MP wide angle camera, Time-of-Flight camera and a 32MP front camera. You will be able to capture stunning and outstanding photos as the SuperZoom lens offers 10X hybrid zoom with rich detail and resolution. Click photographs in low-light conditions and achieve image quality like never before with the Huawei P30 Pro as this smartphone is inbuilt with a Huawei SuperSpectrum sensor.
The Amalgamation of Power and Speed
Powered by the world’s first 7nm Kirin 980 chipset, you will be able to experience a stronger and more powerful performance while consuming lower power. With 8GB RAM, you will be able to swipe through apps without feeling a lag. The Huawei P30 Pro comes with a cooling solution that dissipate heat from the device. Buy this feature-rich smartphone from Huawei at a great price on Amazon.in.
Long-Lasting Battery, Ergonomic Design and New Acoustics
With 4,200 mAh battery, you will be able to stay connected with your loved ones without the worry of running out of battery juice. Made with 3D curved glass, the handset is elegant and gives you a comfortable fit in your hand. Experience stunning and bright colours on your smartphone as the Huawei P30 Pro gives you a 6.47-inch OLED Dewdrop display. This smartphone also uses the Huawei Acoustic Display Technology to provide you with an increased hearing area. What are you waiting for? Get your hands on the stellar Huawei P30 Pro, available on Amazon.in.
https://www.amazon.in/b?ie=UTF8&nod...&pf_rd_p=c9e76be8-cacc-4a4e-a941-0b39bed0a9dd
