BSNL Balance Check Number 2018
BSNL is known for their low-cost tariff plans for Intenet and Calling. That's why BSNL is very popular in the telecom industry. There are so many plans of BSNL checking their usage by using USSD codes. USSD means Unstructured Supplementary Service Data sometimes referred to Quick Codes or Featured Codes. It helps you to get information about your usage for Internet and calling. Here, we will be showing USSD codes that can easy for you to check balance in your mobile
BSNL USSD Codes 2018
BSNL Balance Check -- *123#
BSNL Net Balance Check -- *123*10#
BSNL number check -- 164 or *8888#
BSNL DND Number -- 1909
BSNL Minutes Balance Check ussd codes -- *123*2#
