Airtel Open Network
Airtel open network is checking network strength in your network area. It is made by airtel specially for their customers. Weak network is serious problem for any users. That's why airtel made a network map where you can find out the network towers locality. so, It can give an idea about your network strength.
What do you need to do for check signal strength online ?
Options are likely to see in the map
Red color towers showing as existing tower.
Blue color towers showing as upgrading towers.
white color towers showing tower needed.
Grey color towers forcibly shutdown.
using above steps you can check strength your airtel network.
